Decent Replacement Elec Washer Pump ?
Old Aug 6, 2006 | 05:49 PM
pgtr's Avatar
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
Anybody else had this problem with their washer squirter pump?
For over 20 years we've replacing these things on our '84 Firebird. It's a little pump that slides up into the wiper motor housing and connects to the rubber hoses on the bottom. They just never seem to last - usually the motors hang in there - it's the dinky impeller things that seem to give out. I don't think the last one I put in could have lasted more than 9 months. I've tried GM and aftermarket replacements.
Anybody found a brand that works well or lasts?
(I'm thinking next time round I'll see if I can find an aftermarket 'generic' model and just mount it on the firewall somewhere and wire it up.)
Old Aug 6, 2006 | 06:19 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
huh mine works fine.. your wipre fluid clean? any debri in the tank?
Old Aug 6, 2006 | 11:03 PM
pgtr's Avatar
Maybe it's just me. They just seem to be incredibly short lived. Just using lung power I can easily blow through the hoses and the tank just has the blue stuff. I might look again real close and see if there's any debris but I didn't notice anything obvious.
thanks
Old Aug 7, 2006 | 06:08 AM
Car: 1988 Camaro
Axle/Gears: 2:73's
The only way i coyuld see one of those things going bad, was if you didnt have a fuse or too big of a fuse hooked to the power source...
Old Aug 7, 2006 | 06:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a front and rear pump. I don't use them often and when I do, they seem to be 'dry' (you can hear them working but no fluid appears). If I play with them long enough, washer fluid will finally appear. At any rate, the pump may not be bad at all.
JamesC
Glowsock
Jul 24, 2025 03:15 PM
dutch930
Sep 11, 2015 06:58 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
