flexplate and balancer
Old Aug 16, 2006 | 07:34 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I'm building a 383 with an internally balanced kit.(3.75 stroke,5.7 rods) What size flexplate and balancer do I need? If they say they are internally balanced,that's all I need or because it's a a stroker,do I need something different? Thanks!
Old Aug 16, 2006 | 07:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the rest of your rotating assembly is internally balanced, then you use a normal, neutrally balanced flywheel and damper.
Old Aug 16, 2006 | 07:58 PM
remltr's Avatar
The kit is from cnc motorsports internally balanced forged assembly: crank 3.75 stroke,5.7 h-beams and srp pistons. For a 700r4 I would use a 153 tooth flexplate?
Old Aug 16, 2006 | 11:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The transmission doesn't care which flexplate you use, the starter does.
84LsxZ28
May 17, 2020 02:21 PM
Stangski09
Nov 14, 2015 01:27 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
