Quick fuel pressure question...
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Stock I had:
36 (Vacuum line connected)
45 (Vacuum line disconnected)
I installed an Holley adjustable fuel pressure regulator and started it with the vacuum line disconnected. Set the fuel pressure with the vacuum line off at 48. But now with the vacuum line connected, it is at 40 and not 36.
Is that ok?
Thanks guys
Is that ok?
Thanks guys
Car: 88 GTA "Cocaine"
Engine: 350 tpi
did you plug the vaccum line when you adjusted the preassure.
you are suposed to drop about 10 psi when the vac line is reconnected
Car: 1988 IROC-Z
Engine: 427 SBC
Yes, it went from 48 to 40 with the vac line in. But it was 36 before with the vac line in.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
