Initial starting/running problems... unlike other threads i've seen.
Old Oct 1, 2006 | 01:43 PM
white87iroc's Avatar
My '87 is having a problem when I go to start it in the morning's/first time of the day. It will start fine, no hesitation or excessive cranking. But when it does, it will idle normally and then choke out (die). Then, once I have restarted it, it will stay running but at a higher than normal RPM, around 1500 or so. But then after it has been driven for a second, everything is fine and it will perform beautifully for the remainder of the day. Any suggestions or if anyone knows... please help. I have looked in a ton of formus and exstensively through this one, but have not been able to find anyone with the same issue. thanks guys.
Old Oct 1, 2006 | 10:17 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I'm goning to assume from your username that the engine is a TPI 350. Any mods we should know about? I'd try fuel injecotor cleaner first, see if that helps.
Old Oct 2, 2006 | 04:10 PM
it is a stoke 305, i put the injector cleaner in today and filled up before doing so. I'll see if that helps. I was thinking fuel pump perhaps. but i don't i'm not sure./
Old Oct 2, 2006 | 04:49 PM
sorry i meant to say that is stock 305.
Old Oct 2, 2006 | 07:38 PM
Car: '85 TA
it could easily be an O2 sensor if it's been a while since you've replaced it. it doesnt sound like a fuel pump to me, cuz it runs fine after you get it going. it sounds like something that's starting to soot over with age. an o2 sensor won't throw a code if it's just old and dirty.
Old Oct 3, 2006 | 03:11 PM
ok cool, i'll check that out. thank you.
Old Oct 3, 2006 | 03:19 PM
So i was looking under my hood today and noticed that there was a little bit of smoke (it wasn't white) that really just looked like steam from a stove or something, and it was coming from only the left side of the block. The steam/smoke didn't smell or anything. Do you think it could be that I need to tighten something down? or does it sound more serious?
Old Oct 3, 2006 | 04:06 PM
Car: '85 TA
It could be anything from fluid dripping out of a tranny cooler line to the exhaust to condensattion off the evap canister. You're gonna have to take a closer look
and find out where it's coming from.
Galaxie500XL
Feb 1, 2020 04:53 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
earlpote
Sep 12, 2015 11:55 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Randomtask2
Sep 7, 2015 05:06 PM
