Motor mount insert question
Old Oct 3, 2006 | 06:27 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have installed these mounts before, and they are a pita. My question is, how do you get the Es inserts in the metal clamshell? Can you do it bolted to the car or should you take the mount off and open it somehow? also does ES make a mount withe the metal shell already on?
Old Oct 3, 2006 | 10:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The directions tell you to remove the mount, drill out the rivets, put the insert in, squeeze the shells together with a vise, and use the supplied cable ties to hold it together until you get it bolted back in the car.
I did mine on the car while the engine was out. Removed the lower mount bolt, drilled the rivet, pryed the shell up to get the old insert out and the new one in, and squeezed the shell together enough with vice grips to get the bolt started.
Old Oct 3, 2006 | 03:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you happen to be replacing the front springs at the same time, it makes it A BREEZE since you can get to the nuts very very easily. Kill 2 birds with one stone... If you were doing the front springs / a-arm bushings though.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
