quick question
Old Oct 11, 2006 | 03:39 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
quick question
I thought i would ask, since i dont know, and all of this is new to me. On my vaccum advance distributor, where does the vaccum canister hook up to?
Old Oct 11, 2006 | 03:51 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Quick answer: Vacuum
Old Oct 11, 2006 | 05:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Longer answer: Either the ported advance plug on your distributor, or the manifold vacuum. Pick the one that makes the motor run the best. Chances are it'll be ported.
Old Oct 11, 2006 | 11:01 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
ok, maybe i should make myself clearer, so you guys could do the same. No offense, but this is all new to me. My new distributor has a vaccum advance, and theres going to be a hose coming off of it. Where should i hook that up to? Is the hook up on the carb or on the intake manifold? thanks
Old Oct 11, 2006 | 11:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Intake Manifold would be "manifold vacuum".
Carb will have a "manifold vacuum" port (probably a few), which will be physically, below the throttle blades. When you hook up a vacuum gauge to a "manifold vacuum" port, it'll show you a vacuum reading, say 16", while you're idling.
A "ported vacuum" port, will only be on the carb. Again, probably a few of them. If you check it with your vacuum gauge while idling, it'll show 0, or up to 2" vacuum say.
Checking it with a gauge is your only real sure fire way of knowing which is which.
Manifold vacuum advance on your distributor will give you your vacuum advance, say 18*, at idle, and above, up to WOT basically. Whereas using ported, will give it to you only in cruise mode, or light acceleration sorta thing.
If you have a bigger cam, and need a schwack of timing to get it to idle, manifold vacuum might help you. I'm not a fan of it myself.
Remember, they are bang on the same, EXCEPT AT IDLE. (basically).
Best bet would be to try one, drive around for a few days. Then try the other. The "norm" is ported vacuum, to make a long story short.
Just gotta check, your new dist has a vacuum advance, your last didn't? Most importantly of all, what carb is on the motor?
Old Oct 12, 2006 | 11:24 AM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
carb and intake
Well, Ive been trying to get my old cc quadrajet/cc distributor to work for about 6 months now, and i have come up way short. Cant get the thing to idle on startup for anything. Anyway, i recently came across a good deal on a performer rpm intake, and a performer carb, then grabbed a vaccum advance dist off ebay. This weekend ill be switching it all out and saying goodbye to CC-headaches, and ill prolly see a whole new kinda of headaches, but at least itll be simpler.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
