Compression question
Old Oct 22, 2006 | 02:24 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Trying to figure out different compresion ratios, Only part I don't get is for instance, in dyno 2003, piston down from tdc? and volume above piston?
these are the pistons i have
Keith Black Hypereutectic Pistons: UEM-KB122020-8 - summitracing.com
anyone help me out? what do I fill in for those two categories?
Old Oct 22, 2006 | 06:33 AM
Damon's Avatar
I just woke up so bear with me here......
See the spec called "compression distance"? That's the key. It's the measurement from the flat top part of the piston (not the dome or dish- the flat part) to the center of the wrist pin.
Take 1/2 of your stroke length, or 3.75 / 2 = 1.875
Now add in the rod length, or 6" in this case as that's what the pistons are designed for. 1.875 + 6 = 7.875
Last, add in the "compression distance" of the piston, 1.130 in this case. 7.875 + 1.130 = 9.005" total compression height.
Subtract that from your block's deck height, which is 9.025" for an unmilled stock small block. 9.025 - 9.005 = .020"
That's how far the piston will be "in the hole", theoretically, at TDC.
Old Oct 22, 2006 | 12:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It should calculate the volume for you, once you give it that measurement. Or else you can do the math...
I'd measure this, since you now have the motor apart. Rotate to TDC and use a straight edge and feeler gauges.
Old Oct 23, 2006 | 03:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I know my block has been zero-decked if that helps at all.
Old Oct 23, 2006 | 06:10 AM
Damon's Avatar
Zero decked to those particular pistons? Or to your previous (different) pistons?
You'll notice I used the word THEORETICALLY in my explanation. That's not by accident. As with anything involving specs in a high performance engine they must be checked against actual real-world measurement to make sure theory and reality are in agreement.
This is 2 days in a row that I've replied to this tread immediately after waking up.
Old Oct 23, 2006 | 12:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
You rule Damon, It was zero decked for these pistons.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
