odd engine measureuments
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
ok, i had one of my machinist buddies check the bores and pistons. there is a .001 taper from the bottom to top. all the bores are round to .0005, all of them are 4.001 except #3, it is 4.008 but has a 4.006 dia. piston whereas the other pistons are 3.999.
is this uncommon?
is this uncommon?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
doesnt sound too far off base. In mass production you do have allowable tolerances, couple that with the uneven wear some cylinders may have gotten over the years and here we are.
Or maybe somewhere along the way that cyl got nuked and they only honed that one. ya never know...
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i believe going .010 you can use the stock pistons with just different rings?? maybe im wrong
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well heat issues will cause distortion and cause an out of round pistin and or cylender.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
rehone and run over sized rings with the end gap filed down to specs.
You can also get pistons nurled to make them larger where it counts.
Both still done allot in the lawnmower world where boring a cylinder just isn't cost effective.
Ghettobird52
Jul 5, 2024 11:18 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
