loss of compression?timing?
Old Jan 16, 2007 | 04:16 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
i took my car for a little drive today,, and the only thing ive done to it was set timing counterclockwise a little,,, it had no problems when i drove it the last three times since i set it back,, but today, it severly struggles past 3000, just sounds like the gas pedal wont open anymore,,,,, but i hadr floored. im guessing this is timing related? no obvious backfires,,, sputters, anything,,, just wont rev,,, even when out of gear,,, if i hold it to the floor itll only go to 4500
Old Jan 16, 2007 | 04:22 PM
Well, if you think it might be the "timing" since you've changed it, put it back.
Since you already have, I think you can rule that out.
Doesn't sound like "timing" or "compression" to me. Sounds more like fuel delivery.
Check your fuel pressure, WHILE IT'S IN THE ACT OF SCREWING UP.
It could also be a stopped-up exhaust system.
Before getting into inventing convoluted "explanations", see my signature for helpful troubleshooting advice.
Old Jan 16, 2007 | 04:42 PM
Gramps's Avatar
Car: 87 Camaro IROC
thers no noise of engine knock is there? other than poor quality gasoline, i would also check fuel pressure.
Old Jan 16, 2007 | 05:02 PM
Car: 91 formula ws6
would or could a knock be related to fuel? it is a seriosu problem not being able to go past 3000 in gear and 4500 in neutral!!! if you hold in pinned in gear it does slowly keep climing tho,,, but very slowly,,, kinda coughs
Old Jan 16, 2007 | 08:13 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Maybe the cat is clogged?
Food for thought
Old Jan 17, 2007 | 01:11 AM
Car: 91 formula ws6
bottle mufflers where the cats are,,,,,,
and i thank you all for the help, but i found out what it was
belive it or not the rubber intake adapter (before throttle body) was sandwitching itself closed,,, and it was such a weird feeling to drive it,,, youd swear it was a rev limiter,, plently of power up to 3000,, then no *****
so im making a new intake peice from metal, should be worth some ponies anyways... i also think the air filter is shitty, causing it to suck down like that
Old Jan 17, 2007 | 01:48 AM
Gramps's Avatar
Car: 87 Camaro IROC
awesome, glad to see that it was something completely stupid, thats my favourite engine diagnosis.
theshackle
Sep 17, 2020 08:26 AM
evilstuie
Jan 9, 2020 08:29 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
