Cams
Old Jan 20, 2007 | 11:24 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Cams
Hey, i have 2 cams and i don't know what kind of performance they would do to my car one is marked GMC / D.5 / 23 / 1539 (6), the other is marked 6930X / GM88 / G25.
I think the second one is a crane cam but not positive.
If i run one of these cams i will be getting my Q-Jet rebuilt to run with it,
a Edelbrock Performer Manifold and i will be cleaning up the stock 305 heads. (can't afford the $1800 Dart heads that i would like)
Old Jan 21, 2007 | 10:07 AM
Damon's Avatar
If it's an aftermarket cam it'll almost always have it etched into the end of the cam along with the grind number. Those numbers don't sound like a Crane numbering scheme.
Old Jan 21, 2007 | 02:41 PM
VenomX-87's Avatar
I was also told that one of them is a solid lifter cam.
Here is a post from someone else that has the same problem that i do with the 6930X: http://67-72chevytrucks.com/vboard/showthread.php?t=210402
Old Jan 29, 2007 | 11:57 PM
VenomX-87's Avatar
Dose any one know what these cams could be and if one of them would be a reasonable upgrade for my L-69?
They both came with a mates 327 when he got the engine and he didn't know what they were.
I now have the 327 but it is just a short block on a engine stand that needs heads, that is one thing i can't aford atm.
but any way will one of these cams work good in my L-69?
Old Jan 30, 2007 | 12:00 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Man, it is not usually a good idea to use a used flat tappet, especially as cheap as they are these days new...
Old Jan 30, 2007 | 12:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You could buy a cheap degree wheel (it'll come in handy later), and set up a 1" travel dial indicator and get a decent approximation. You can get your max lift, .050" duration, etc. LSA if you do a bit of math. That's a pretty good idea actually, if either cam is worn down, the dial indicator will show it.
Old Jan 30, 2007 | 02:36 AM
VenomX-87's Avatar
The GMC / D.5 / 23 / 1539 (6) has high and narrow lobes and
The 6930X / GM88 / G25 has wide and mid hight lobes
Old Jan 30, 2007 | 03:09 AM
VenomX-87's Avatar
oops i didn't mean to post it two times how do i delete this post
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
