Please explain how to adjust the timing with a vac dist total and base
Old Feb 10, 2007 | 11:14 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am either going to be useing a mallory or a msd distvac advanced dist, I was wondering ho do I achieve the total timing number? do I want the vac advanced hooked up how much do I want and by what rpm? the motor is a 350. what is mec advance and what is vac advance? how do they all work together to get the final 36 to 40 total? how do you set each?thanks
Old Feb 10, 2007 | 01:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 36 degree "total timing" number doesn't include the vacuum advance, it's just the centrifugal advance plus the base advance.
Old Feb 10, 2007 | 02:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
look on the main page of TGO for an article about "high performance HEI ignition" or something along those lines. Written by Damon I think. He lays it out step by step.
Old Feb 12, 2007 | 11:39 AM
BLACK Z's Avatar
Car: 86 Z28
So if i set the timing to 10 at idle with the vac dissconnected, And say the dist has 20 built in to it, I would then bring it up to 3,000 rpm with the vac still distconnected and I should have thirty at this point? If I would want 38 I would have to set the base at 18? Do i want to check it with the vac hooked up? at all?
Old Feb 12, 2007 | 12:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's pretty much it. Adjust your centrifugal advance so you've got about 34 degrees or so at 3000 RPM, or sooner if the engine will take it without pinging at WOT.
After that you can adjust the vacuum advance curve to avoid pinging under part throttle.
Old Feb 12, 2007 | 03:19 PM
BLACK Z's Avatar
Car: 86 Z28
Do i need to check what the timing is when the vac is hooked up? some come with a adjustable vac advance some do not, if they don't come with one how do you adjust it? if you need to buy a adjustable can is it worth it? thanks
Old Feb 12, 2007 | 04:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
if they don't come with an adjustable vacuum can - you can't adjust it.
I think it's worth it, having the rate, and amount of vacuum being adjustable there. The Crane one is what I have, and I like it.
Yea, you don't really need to check your timing with a light with your vacuum can hooked up. Unless you want to hook it up to manifold vacuum just to verify how many degrees you're getting max.
Did you read the article I pointed you to? All the info is there, ie, how to adjust it, etc.
Old Feb 13, 2007 | 06:11 AM
BLACK Z's Avatar
Car: 86 Z28
Yes I read the article, so the dist should be hooked to ported vac, but I can hook it to manifold vac to check total timeing? would i leave it at idle to do this? thanks
Old Feb 13, 2007 | 12:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Well, no. "total" only refers to base, + mechanical advance. But that's just symantics technically.
Yes, you can let it idle, and hook up to manifold vac to find out the max timing you're getting from the vacuum can. timing, subtract your base, is your vacuum timing added.
Assuming lets say you're getting 18" vacuum at idle, and at cruise you might be getting 24", so we're assuming your vac can is maxed out by 18". Or whatever you've got at idle. That way this test will work.
If this amount of timing (could be upwards of 30*), raises your idle speed to where your mechanical advance is kicking in, then again, this is meaningless. You'll have to close your throttle blades until it's below the mechanical advance period. So it can get tricky, but you'll figure it out.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
