WOW I THINK I FOUND MY ROUGH IDEL
Old Mar 11, 2007 | 12:52 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I was looking at my car at school trying to find why my car is dying at red lights and have a rough idle. so i started looking at lines and i notice two vacumn lines broke going from my egr valve to the egr soloid [ look at pic] I need to know if they would sell this at a local parts store. thanks
Attached Thumbnails WOW   I THINK I FOUND MY ROUGH IDEL-egr-005.jpg   WOW   I THINK I FOUND MY ROUGH IDEL-egr-006.jpg
Old Mar 11, 2007 | 01:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh, those stupid hard brittle plastic lines... I've never seen 'em at a parts store, but i've never really looked either.
GM should be able to get 'em for you if a parts store doesn't have them.
Old Mar 11, 2007 | 01:27 PM
EvilCartman's Avatar
Car: '82 Z28
Screw those plastic lines if you're able to replace them with a regular vacuum hose. Cheaper and more forgiving when you're working on the engine. One wrong bump to an old plastic line and it's busted.
Old Mar 11, 2007 | 01:51 PM
firstfirebird's Avatar
Look in the aisle with the "HELP" products and miscellaneous fittings. You can just use soft lines like mentioned before. They usually will have tees, wheys, strait and 90* connectors, just make a diagram if you don't know where each one goes. Sometimes you will see those hard lines as well.
Old Mar 11, 2007 | 02:37 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
tell me about it, i just bumped a line going into the firewall and now i cant switch the vent direction
Gotta fix it soon cuz my idle is going crazy lol
Old Mar 11, 2007 | 07:41 PM
Car: 91 formula
but do u guys think that the egr lines would cause my rough idel??
Old Mar 11, 2007 | 07:49 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Old Mar 11, 2007 | 08:06 PM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
here you go http://tpiparts.net/82_92_emissions $26.00
Old Mar 11, 2007 | 08:28 PM
Absolutely! If any of the lines are even leaking will cause rough/high idle because you are getting too much air into the intake.
Old Mar 12, 2007 | 09:53 PM
Car: 91 formula
Originally Posted by glock
very good but it says it only goes for 89-92 tpi engines. I have an 87 engine. does it matter? i need to know
Old Mar 12, 2007 | 10:55 PM
glock's Avatar
Car: 1989 gta
i dont think so..... try matching what you have to that picture.....i know the small line goes to the egr and the long one goes to bottom of the throttle body
Old Mar 12, 2007 | 11:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Buy some steel brake line and bend it yourself. Easy to do, and it makes for a bulletproof connection.
Old Mar 13, 2007 | 08:44 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
If you buy a new EGR solenoid it comes with those lines attached to the new part. If all else fails...
Old Mar 13, 2007 | 05:44 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
They sell those hard plastic lines at autozone. I just bought some the other day.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
middian
Sep 5, 2015 01:42 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
