ignition problems
Car: 1987 Pontiac Trans Am
Engine: 355
Axle/Gears: 10 bolt gm
ignition problems
ok i have been having some huge problems with my ignition switch! i tried changing the lock cylinder and the thing still won't turn off the radio and i can't get the steering wheel to unlock and the key to go to the on possition any ideas or any of u had this happen and know what to do to fix it??
HELP PLEASE!!!!!!!!!!!!
Car: 84 sport coupe
Engine: 2.8,for now
Axle/Gears: junk
Re: ignition problems
have you tried replacing the switch itself? disconnect the batt,remove the switch,and make sure the rod is not bound up somehow
