code 43 keeps coming on
Old Apr 5, 2007 | 10:18 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
I keeep getting a code 43 which is the esc on my 91 z 305 tpi I have put a new comp on it about 2 months ago but I dont know whats going on can someone give me some input please??
thanks
steve
Old Apr 5, 2007 | 10:34 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: code 43 keeps coming on
i belive 43 is for the knock sensor,
search it works
Originally Posted by RBob
This is a knock detection system error. It can be caused by a number of items. Which item can be narrowed down by when the SES lights up for that code. It it happens shortly after starting the engine then the knock module or wiring to/from the module, ECM, and power may be the issue.
If the SES lights shortly after or during heavy throttle usage, then the forced knock test may be failing. This is done by the ECM once the engine is up to temperature and the ECM goes into PE mode (WOT). Timing is added to force knock to occur. If it does occur everything is OK.
If after 2 attempts to force knock fail to produce knock (as seen by the knock detection system), code 43 is thrown and timing is reduced (will feel a loss of power after that).
The forced knock test can fail from too high an octane fuel, or improper base timing. Engine mods can also affect this test. Of course a bad knock sensor or module will also cause this to fail. Although you could probably hear the poor engine knocking away.
RBob.
hectre13
Dec 11, 2023 08:14 AM
chazman
Aug 28, 2018 03:25 PM
apie2546
Aug 10, 2015 05:43 PM
