AirCon Delete on a 89GTA
Old Apr 6, 2007 | 02:56 PM
Dr G's Avatar
Hey all, I'm just fitting my air-con delete box and had a question about the wiring.
I found this thread https://www.thirdgen.org/forums/el...=Aircon+Delete (A/C Delete wiring)
Which says that you dont need the relay and that the chap just cut the loom back.
i'm happy with reconnecting the coloured wires but can i just chop back and tape up the other wires? These are;
Small Green
Small Blue
Medium Red
Medium and Small Black
The Green and blue ones are the ones that goto the sensor on the air con resivoir. and I'm assuming the red is a live and the blacks are a ground, to wich i connect the other side of the motor.
Is this correct?
Cheers
since the last post i've discovered that the green and blue wires for the air con sensor go back to a multiplug thing with the big black one. as does the red one goto its own connector. can these just be unplugged? instead of snipping and tapeing them up further up the loom towards the fan.
Cheers
actually, its a different green wire, its much darker and it goes back in towards the cars loom.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
