starting problem
Car: 1988 camaro
Engine: 2.8 tpi soon 383
Transmission: 5 speed manual
starting problem
ok im still having trouble getting my 88 camaro rs to start its got the 2.8 mpfi V6 in it ive replaced the
starter
coil
wireset
gas lines
i hear the fuel pump charge and it just constantly cranks it sometimes sounds like it fires/backfires anybody have any ideas?
starter
coil
wireset
gas lines
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: starting problem
check ESC Electronic SPARK Control, its located near the brake booster on the driverside near top of the fire wall. Also check you starter/battery connections and check your spark plugs, wires, distributor cap/rotor and ignition control module.
also check your battery voltage. might have power but not enough to start the car which asks for the full 12v/whatever amps it produces.
if all that checks out then i'm lost as to what else it could be. Thats your electronic system right there and don't forget the altnernator.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Well let's talk about it? Is it cranking? Is it clicking? Is it doing nothing?
Let us know and we can better assist you.
Axle/Gears: no idea
i had a problem where i would here clicking and no fire/spark
take key out and try again it would start. turned out to be corroaded connection at the atarter and battery. the electricity was arcing to make contact
clean and check connections at the battery and starter
give it a try
give it a try
Car: 87 Camaro IROC
did you do any engine work (ie: swapped motor) that would cause this or did it just happen one morning?
Car: 1988 camaro
i bought the car as a project after i wrecked my 81 ta the car wasnt running at the time i replaced the fuel lines, fuel pump, fuel filter, starter,coil,spark plug wires, spark plugs. and hooked up the 700 cranking amp battery from my truck ive tried the key thing and still nothing when i say its occasionaly fiing i mean it will fire maby once the nothing......i dont know ideas?
Axle/Gears: no idea
prolly dumb question but did you check the fuel fuse? its located near the battery.
just one extra thign to check. probably not your problem but I'm mentioning it anyway
Car: 1988 camaro
ya ive checked the fuses they all seem good the fuel seems fine cause ill spend all day trying to get it to start and at the end of the day ill have less gas than b4. i think its somthing with the spark i cant think of anything else besides the distributor that would cause this any ideas?
Axle/Gears: no idea
mayeb the spark which is why i mentioned the ESC and the ignition module. maybe cap or rotor or maybe plugs themselves or wires but i think its something before it gets the plugs so more likely ESC igniton module cap or rotor
92camaroJoe
Aug 13, 2015 06:07 AM
