heads
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
heads
im interested in installing headers that are on order already, i need to find the casting number in order to tell weather my 305 has d ports rectangle oval ect, where is this number located??
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: heads
Under your valve covers.
If you would have put your car information in your profile, so it shows up on your sidebar, I could have saved you the time and told you right away...
They'll either be 416's if you have an early carbed motor, 187 if you have TBI engine, or 081 if you have the later TPI setup.
I'm pretty sure they're all considered D ports, but it doesn't matter in the slightest really.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: heads
The only factory head that needs a Dport shaped exhaust flange is the Corvette L98 aluminum heads. (113)
Car: Camaro RS
Engine: 305 tbi
Re: heads
sorry im new to this, and i have the 89 rs 305 tbi. i was under the assumption that it had square or slightly rectangular ports.
Car: 1982 Trans-Am
Re: heads
Yea you have the 187 heads. AFAIK it's the "normal" factory SBC port. I guess it would be called square?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
