port job
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
port job
i have aluminum heads from an 90 vette. Im thinking about porting the heads out.
1st, will this be a very good upgrade?
2nd, how much should a port job cost?
3rd, are there different stages of port jobs?
also with a port job, will have to change any of the valvetrain?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: port job
This should probably be moved to the general engine board, but since im here:
It is a good upgrade, if you work it right, you can make those heads breathe alot better.
Not sure about cost though, I did my Brodix heads on my own. There are very specific guidelines you have to follow though, its not just all about removing material.
Valvetrain, no you dont need to change anything provided that all you are doing is porting the heads.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: port job
I agree, not sure how much you'll improve on your 400RWHP and 500RWTQ though,
Car: 1982 Trans-Am
Re: port job
Yea, well, good luck with that. Did you dyno your current motor? Not trying to be insulting, but those '90 Vette heads are the L98 AL ones IIRC. I think those flow in the 205CFM range or something? I have a real hard time believing your 400RWHP dyno #, hence why i'm leery on thinking you'd hit 500RWHP after porting them.
Re: port job
They were the L98 aluminum ones.
You won't be fetching 106hp with a port job, unless you are going 100shot of spray too.
Expect around 10hp from the mod if it is done right. 20hp is a three pointer from half court, but I've seen it done before.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: port job
dyno @ 394rwhp and 479 rwtorque
That would be about 315rwhp.
2012sergen11
Oct 13, 2015 07:38 PM
