fuel issiue
Car: 1982 z28
fuel issiue
ok its a 91 camaro rs 305 auto tbi. it ran good and i went to start it the other day and it was hard to start and then died a few min later after idleing. it wouldnt start back up and its getting no fuel. i no longer hear the fuel pump coming on either anymore. i checked the fuse its good. in my haynes manual it has the direction for running a power wire to a spot on the diagnostic box but where it shows to put the wire there isnt a metal clip in that spot. im wondering y? and is there any other way to test whether its my pump or relay?
thanks steve
thanks steve
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: fuel issiue
yes i believe that the ecm will bypass the relay once the engine sees 4 psi of oil pressure so it might take 5-6 secounds of cranking to get the pressure but dont take my word for it i havent needed to test it
Car: 1982 z28
Re: fuel issiue
the fuel pumps not going on at all, i can crank it over and over again with no start
Car: 91 RS
Engine: 350 vortec
Re: fuel issiue
well you should check fuel preassure before you drop the gas tank might save you a few days under the car...
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: fuel issiue
Where's it show your clip? Should be rear left engine compartment by the relays. To the left (outside) of your brake booster and behind your strut tower. The connector takes a spade (flat) fitting.
Car: 1982 z28
Re: fuel issiue
o in my book it shows the diagnostic thing inside next to the fuse panel port g. is there another way to test the fuel pump?
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: fuel issiue
Look in the engine bay right in front of where the driver sits and by the relays that are mounted to the firewall. There should be a single wire with a connector at the end of it connected to nothing. That's your fuel pump test port. Apply 12 volts to it and the pump should keep running.
Car: 1982 z28
Re: fuel issiue
i searched and searched and could not find the wire with the clip you posted about, could it be somewhere else? what color is it? does anyone have a diagram or something with all the fuelpump related wires and connectors and what color wires they are or pics would greatly help
thanks steve
thanks steve
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: fuel issiue
My 89 Bird 305 TBI has fuel pump prime, it is a red wire to the normally closed contact in the relay, it is in the ALDL don't remember off hand which term. I used it to drain my tank for a pump upgrade.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: fuel issiue
My pump wasn't priming last night so I tried the test terminal, but it didn't work, I've used it to drain the tank as well, so I know it should work.
I removed the relay and jumpered the org and tan/wht wires, I could hear the pump trying to turn, but wouldn't, the jumper just got hot. Fortunately I have a "hacked access door" so pulling the pump out is no problem.
Car: 1982 z28
Re: fuel issiue
yep i found the test wire it was on the opposite side as it should be, but the pump tries to turn but wouldnt so now i get to have the fun of changing that
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
