throttle randomly sticks, only w/ air filter on
Old Apr 28, 2007 | 09:09 AM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
hey, ive got an 84 Trans am and i just got a remanufactured carb because i cracked the old one and now it idles normally, for the most part, and then if you gas it the throttle (sometimes) sticks at about 3k but i cant get it to do it with the air cleaner off, and i cant see anything thats binding so hopefully someone has an idea what this could be.
Joe
Old Apr 29, 2007 | 08:32 PM
89 Iroc Conv.'s Avatar
Re: throttle randomly sticks, only w/ air filter on
Joe
The linkage has to be hitting the filter is it a drop base filter, put a little grease on the top of the linkage install the breather open the throttle then take off the filter and see if the linkage left some grease on it if it is there is your prob.
Old Apr 30, 2007 | 12:44 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Great idea with the grease method bro.
Also, get a second person to help you out here. Have them pump the throttle from inside the car while you watch the linkage to see if you can see the point at where it gets hung up. Check for any moving parts that are contacting (throttle cable, linkage, return spring, etc. You'll figure it out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
amargari
Nov 10, 2015 02:09 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
Jk_Under
Sep 8, 2015 08:13 AM
