TPI not starting-just turning over
Old Apr 28, 2007 | 09:57 PM
hedgejj's Avatar
Car: 1931 Chevy Sedan
Engine: 1990 5.7L TPI
I have a 1990 TPI 5.7 that was starting fine, and now will not hit a lick...
I have done the following:
checked for spark on both sides-good
checked injectors on both sides with a light--good
fuel pressure is at 45psi with ingition on
confirmed timing at (#1 at TDC and distributor is ok) was timed 6 deg, but wanted to confirm
checked plugs by pulling -good spark
changed ecm (122-7730) just in case
Also checked TPS voltage ~0.52 volts
took ignition module in and had it checked---it's good
no codes but 12--good
replaced the dizzy pick up coil
held throttle wide open, clear flood mode--didn't start.
went thru swappers guide and all checks out
What am I missing, why won't it fire, i mean i have spark , fuel??
I do smell fuel....
I am to the point were it has to be a electrical issue somewhere??? any direction, it went from running to not firing?????
Old Apr 29, 2007 | 11:09 AM
Re: TPI not starting-just turning over
I'm going to guess there's some history here that we haven't been told about.
What happened when you did the most obvious thing, which of course was when you just put in NEW spark plugs?
Old Apr 29, 2007 | 04:15 PM
hedgejj's Avatar
it was running and started on first crank every time. It was having idle in drive problems, contacted a guy and he said the fuel pressure was too high, it was around 50psi. So, when adjusting the fuel pressure (I have an adjustable regulator and gauge) I was told to disconnect the vacum line for a more accurate reading. I know I plugged the line coming from the maniflod but cannot remember if I plugged the line to the regulator. It almost fired once then nthing since. I kinda thought it could be the fuel pressure regulator, but it is holding pressure and plugs are getting fuel.
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
