Code 32 / EGR problem?
Car is an '84 l69 trans am. Just rebuilt engine, new EGR valve. I have checked all the vacuume lines. I get a code 32 about 5 seconds after starting the car. Any thoughts? From searching threads, it appears most people have this problem at cruising speed, not idle.
Re: Code 32 / EGR problem?
Thanks, I will check that out. I was also just reading another thread and saw where some heads actually do not have EGR passages. I have World Products S/R torquer heads. If they didn't have the passage I assume this could be a problem. If this is the case, is there any way on an '84 ECM to disable the EGR/code?
mdtoren
Aug 16, 2015 05:45 PM
