motor locked up
Old May 15, 2007 | 04:38 PM
ghotachevy's Avatar
motor locked up
started ran for a sec shut off and doesn't want to turn anymore main bearing or more likely cam?
Old May 15, 2007 | 04:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: motor locked up
Can you turn it over by hand?
Old May 15, 2007 | 04:45 PM
ghotachevy's Avatar
Re: motor locked up
WITH A BREAKER BAR
Old May 15, 2007 | 04:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: motor locked up
By any means possible, but preferrably not by turning the crank bolt.
Old May 15, 2007 | 05:08 PM
ghotachevy's Avatar
Re: motor locked up
no i mean only with a breaker bar it will turn not turnin like it should bought the long block from some one and it was just rebuilt
Old May 15, 2007 | 05:15 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: motor locked up
Hmm, take off all the belts, and then try to turn it over. Hopefully a accesory just locked it up. Just because its rebuild doesnt mean its good. people make mistakes....
Old May 15, 2007 | 05:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: motor locked up
So it turns with a breaker bar, but not with the starter?
Old May 15, 2007 | 05:30 PM
ghotachevy's Avatar
Re: motor locked up
only runnin a alt and water pump both brand new
Old May 15, 2007 | 05:36 PM
ghotachevy's Avatar
Re: motor locked up
it will turn but barely not like it should
Old May 15, 2007 | 05:52 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
Re: motor locked up
possible an overtightend fastener? seems unlikely though. im curious as to what this may be also
Old May 15, 2007 | 07:06 PM
ghotachevy's Avatar
Re: motor locked up
took belt off got it to start ran fine for the min i had it on knock startin so take it out again somethin on pass side oil press is still 60 lbs
Old May 15, 2007 | 10:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: motor locked up
pull the plugs and try turning it again if it isnt pretty easy with the breaker bar then it needs to come apart... that fact that you know the knock is from the pass side means its probably a rocker not adjusted properly
Old May 15, 2007 | 10:28 PM
ghotachevy's Avatar
Re: motor locked up
its comin apart its actually already out this is the only motor i din't build goin in one of my cars and look what happens not a rocker went over them twice before initial fire up car ran fine for two days the knock is a thud sound just faintly startin what u think chances of swapppin out bearings and it be ok
Old May 15, 2007 | 10:32 PM
Car: 91 RS
Engine: 350 vortec
Re: motor locked up
you could probably get away with it as long as you fix what ever nuked it in the first place along with a very thorough cleaning
Old May 15, 2007 | 10:39 PM
ghotachevy's Avatar
Re: motor locked up
i dont know got a few cranks layin round mine as well check some numbers on them and just swap crank and bearings
Old May 15, 2007 | 10:42 PM
Car: 91 RS
Engine: 350 vortec
Re: motor locked up
anything you could do to ensure the life of the motor would be worth it at this point... i am sure pulling the engine every other week would get old fast
Old May 15, 2007 | 10:48 PM
ghotachevy's Avatar
Re: motor locked up
Old May 15, 2007 | 10:58 PM
ghotachevy's Avatar
Re: motor locked up
considering what i paid for it 5 months ago to find this out two days after its in the car gonna go beat on that guys door tomorrow whole diff. thread there but yea a lil pissed off today i know the motor was just rebuilt i put the heads on and diff oil pan so i got peek at it all
Old May 24, 2007 | 12:19 AM
ghotachevy's Avatar
Re: motor locked up
well she's all broke down i found a spun rod bearing on 8
and then there is the weird thing we'll see what you guys think
on #2&3 (i think dont remember) pistons have a little piece broke off very bottom of skirt
did this guy degree the cam wrong cause it looks like the lobes on the cam hit it
or what the hell would cause that
Old May 24, 2007 | 06:50 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: motor locked up
he might have put the rods on backwards causing the bind which in turn screwed up the piston skirt. Just a thought.
Old May 25, 2007 | 07:52 AM
ghotachevy's Avatar
Re: motor locked up
idk all the notches on pistons were facing right way
so that would mean it was the people who pressed them for him
Old May 26, 2007 | 03:32 PM
Car: 91 RS
Engine: 350 vortec
Re: motor locked up
or if this engine has been run before you got it , its probably seen some 7500+rpms i pulled a engine out of a truck with a blown tranny every piston skirt was cracked... truck only had first gear...
Old May 26, 2007 | 03:37 PM
ghotachevy's Avatar
Re: motor locked up
no it was new
dont matter crate motor is already here on stand being painted as we speak
well not as we speak but u know
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
