how well will this combo work
Just ordered the last of the parts i needed to finish my motor im curious on how well everyone thinks this combo will work 11:1 406 eagle rotating assembly trw forged pistons AFR 210 100% CNC heads Brodix HV1000 intake Lunati solid lifter drag cam 3800 – 7200 Valve Lift Intake 0.550 Exhaust 0.571 Comp pro magnum roller rockers holley 830 HP carb and full msd ignition
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: how well will this combo work
Could run like a raped ape. Could run like a 3 legged goat. Depends a lot on the unknowns.
I personally would have done solid roller for that type of motor.
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
