Tachometer help?
Old Aug 19, 2007 | 06:19 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Tachometer help?
The tachometer in my 84 berli is terribly calculated for the v8 i've installed, this car came factory with the 2.8, but already had a blown v8 when i bought it. It's nearing it's final stages of paint so of course i want everything taken care of.
What would be a better option installing an aftermarket tach or somehow fixing the stock one to work correctly.
Old Aug 19, 2007 | 09:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Easiest would probably be to get a factory Camaro V8 tach and put it in place of the V6 tach.
Next would be putting a V8 circuit board on your V6 tach.
Hardest would be an aftermarket tach, but depending upon what you got, it is probably also the most accurate.
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
99Hawk120
Mar 13, 2002 02:24 PM
