383 question???
Old Aug 27, 2007 | 08:40 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
383 question???
OKay Im looking to sell my bike and get a 83 Z28 with..
383 Stroker
Dart Heads 202 Intake
5 speed
3.73s
Holley 600 Carb
4pt cage
Frame tied.
Okay Now I called the guy and it has 3800KM on the drivetrain. He ran it this weekend and had some issues it was bugging down. I saw it run (didnt even know it was the car im looking at lol) It seemed to be hooking way too much for his RPM.
The best he ran was a 13.80? He said the carb is too small and it needs different slicks and it will go 12s.
Now I was wondering If I did buy this car. Could I swap everything from a 305 TPI onto it?? (injectors,fuel system intake etc) or should I go with a 650 Carb?
It just seems that it could run alot faster than it does.
BTW he is asking 5500 CDN the car sat for the last 2 or 3 month with no bits also. So I may be able to work on the price a bit.
Thanks Jay
Old Aug 27, 2007 | 08:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 383 question???
you could swap the tpi onto it if you wanted to make it extremely slow. A carb would be a better choice but 650 sounds a tad small for a 383..
Old Sep 5, 2007 | 06:04 PM
crazycuda's Avatar
Re: 383 question???
With out knowing the cam specs and compression ratio picking a carb is really a vrap shoot. From personal experiences with 383's a 750 dbl pump works real nice until you get into crazy cams, with high compression ratios
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
