A quick question about a transmission
Old Sep 7, 2007 | 10:49 PM
malkavian's Avatar
I have 2 engines and will be building one of the two. One is a 400 and the other a 350 both 4 bolt mains. Both out of old rv's and they have the 2 piece ream main seal. I have been looking for a donar car to get a t-56 and all parts out of to swap into my 92.
I have been told over the course of 5 days by 6 diffrent people that a t-56 will not work with a 2 piece rear main seal engine. I have not been able to find out for sure was hoping some one here knows for sure.
Kip
Old Sep 7, 2007 | 10:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: A quick question about a transmission
It will work fine as long as you use the appropriate flywheel to bolt to the 2 piece RMS crank.
Old Sep 7, 2007 | 11:06 PM
malkavian's Avatar
thats what I was thinking but had wanted to be sure before I started ordering my crank pistons and rods lol.
Old Sep 8, 2007 | 05:58 AM
You would need this flywheel if you run a 350, or this one for a 400.
It's not unusual for 6 - or even more - people to be wrong. Remember that at election time.
Old Sep 8, 2007 | 01:42 PM
malkavian's Avatar
thanks sofa...That helps was about to get on the horn and find out which flywheel I needed .. Thanks again ...
Old Sep 8, 2007 | 05:21 PM
get on the horn
And most likely, you'd have got 6 more wrong answers, from 6 more people who didn't have a clue what they were talking about but "thought" they knew everything...
Sucks to be a human. I've discovered since I've been assigned to this miserable planet, it's hard to soar like an eagle when you're stuck in the middle of a flock of turkeys.
Old Sep 8, 2007 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
When's your tour of duty over?
Old Sep 8, 2007 | 05:32 PM
Tours of duty are irrelevant. Resistance is futile. You will be assimilated.
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
