Alright guys need some backup here.
Old Sep 13, 2007 | 11:53 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I've got a 88 350 TPI stock. I'm ripping out the EFI and putting a carb on. But I figure while I'm at it I'll put a new cam as well.
I really need you guys to suggest me some parts. You see I know everything I know about my cars from my dad. But now that I'm a little grown up (22) and I've obviously moved out years ago. I'm sitting back without the constant help from the pops.
So, beside that rant there.
I would like to put a cam in along with my new carb, intake, etc. Can anyone suggest a lumpy cam with some power gains that will work with my stock engine the way she sits.
Or, if the price is right... Perhaps some heads to go along with a cam.
Just looking for suggestions on part combos fellas, and I'll research it and make some decisions.
Thanks fellas!
Old Sep 13, 2007 | 11:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Alright guys need some backup here.
Stock heads are going to be a big limitation on how much cam you can run. You'd have to have the valve guides machined down and the spring pockets enlarged. After that, something like an XR276 might get you what you want. You'd want a new torque converter with it though.
Old Sep 14, 2007 | 12:57 AM
Daishi's Avatar
Really seems like I should be going with new heads then...
Perhaps someone knows of a good cam/heads combo?
Old Sep 14, 2007 | 01:00 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The heads you've got are fine, they're some of the better ones that GM ever produced. They just need a little relatively inexpensive machine work to handle more lift.
Old Sep 14, 2007 | 01:03 AM
Daishi's Avatar
Heh, the list of things to do is getting bigger. So say I went and got the heads done. What suggestion of a combo can you reccommend to put in the heads along with the XR276 cam?
Old Sep 14, 2007 | 01:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Comp recommends their 986 spring with that cam. Along with those you'll need new retainers, locks, and valve seals, none of which are really expensive. Those are all part of normal head rebuild. You could upgrade to larger intake valves at the same time if you like. Call a local machine shop for prices on the work. I get a standard valve job and assembly for about $100 a head here, but that doesn't include machining the valve guides and spring pockets. It should still end up costing you much less than a new set of heads.
BTW just because I'm using a Comp cam as an example doesn't mean that Crane, Lunati, etc. don't have something equally good. I just use Comp because they gave me a free T-shirt once.
Old Sep 14, 2007 | 01:17 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
You'll want about a 2000 stall torque converter with that cam also. I believe if my memory is correct, power starts with that cam around 1900
Old Sep 14, 2007 | 01:20 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I do happen to have a 2000ish RPM converter I'm trying to get rid of. If you decide to go that route, PM me if you're interested.
Old Sep 14, 2007 | 01:22 AM
Car: 91 Camaro RS
Engine: Small Block
There you go, Apeiron is hooking you up with one step closer to your goal!
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
articwhiteZ
Aug 7, 2015 02:25 PM
