Strange noise coming from the engine bay
Old Sep 14, 2007 | 10:09 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
My car started making a ticking sound a few days ago. I think it could be the alternator or the smog pump bearings (or whatever is under the alternator). The sound changes volume randomly. It occurs all the time. Check out this video and let me know what you think the noise is:
http://www.youtube.com/watch?v=QcxfuOh-vro
Old Sep 15, 2007 | 03:11 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: Strange noise coming from the engine bay
Kinda hard to make out the exact noise you are reffering to but I would start by checking the all the pulleys to see if any are loose or maybe bent causing what I heard. Sorry I cant be more helpful.
Old Sep 15, 2007 | 08:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sort of sounds like the A.I.R. pump. Take the belt off of it and start up the engine. If the noise goes away, it's the A.I.R. pump. If it doesn't, take off the next belt and see if it goes away. If it does, it's one of the accessories run by that belt. Etc., etc.
Old Sep 15, 2007 | 08:21 AM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Sounds like the air pump
Old Sep 15, 2007 | 01:30 PM
Thanks, ill try out your suggestions.
Old Sep 20, 2007 | 11:12 PM
Yup, it was the A.I.R. pump. I tried turning it by hand and it would stick at certain points, scraping against the casing I guess.
Replacement set me back $50. Could I have just removed the belt and put it back on for inspection next year? How much would not having the AIR pump operating properly affect drivability?
Old Sep 21, 2007 | 12:25 AM
five7kid's Avatar
If you just took the belt off, most likely the pump would have seized within days. Quite often when the pump has gone bad, the check valves have as well. If the pump isn't running, exhaust is going to back-flow into the pump and rust it up.
Not having the pump running will not affect driveability.
pimp2303
Jul 27, 2017 02:03 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
