FITTING COATED PISTONS ?
Old Oct 7, 2007 | 02:17 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
well im getting ready to install pistons. its my first time using coated pistons. block was bored 4.030, piston dia. says 4.02875 with .001 clearance. so 4.02975 (4.03) is good.
direction say you cant measure coated pistons. so when i put a piston in the bore top down it goes in fine but when it hits the skirt with the painted speed pro logo on it they get snug. with a little rotating it finally moves nice. is this normal ? will the logo just wear off ?
just want to make sure this is right. "its my first time".
then theres all that lost h.p. if the logo wears off.
thanks
mike
Old Oct 7, 2007 | 02:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: FITTING COATED PISTONS ?
Go by the directions given by the piston manufacturor. I did with mine. No problems.
Old Oct 7, 2007 | 05:06 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
it is normal for them to be snug... as you only have .0005 space around the piston... be careful with them you dont want to do ANY damage to the skirts... NO scratches no anything
Frozer!!!
Jan 19, 2024 04:55 PM
tom1985
Apr 19, 2016 07:55 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
