What are standard problems?
Old Oct 27, 2007 | 01:30 PM
PJ_MISC's Avatar
Are our motors prone to any problems?
Stuff that goes bad or poor oil circulation or any thing just curious.
Old Oct 27, 2007 | 03:18 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: What are standard problems?
not that i know of, the only problem i've run into is that stupid vats problem, it didnt act up until i hooked up the obd and it threw like code 53 and then it started getting touchy on me and wouldnt start, i just bypassed it like everyone else though
Old Oct 27, 2007 | 04:53 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
The motors themselves are pretty bulletproof.
Old Oct 27, 2007 | 05:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The only "notorious" kinda problem the SBC has is oil leaks... because all the covers etc are made from stamped steel, oil leaks are pretty common from the valve covers, timing cover, and oil pan rail. These are very minor issues though, and can easily be corrected.
Old Oct 27, 2007 | 06:47 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
The valve stem seals going bad with the higher lift cam in the performance motors seems to be a recurring problem. The TPI motors have to have the throttle body cleaned periodically (every 15 years or so) or the "surging Idle" happens.
The AIR pump should be replaced before it hits 20 years old.
If the coolant in a 3rd gen has never been changed, you can expect the heater core to spring a leak.
The headlights on any Firebird should not be expected to raise after 15 years without being rebuilt. These issues have been covered extensively in numerous post thru the years .
Is this kinda what you were asking?
Old Oct 28, 2007 | 12:18 AM
PJ_MISC's Avatar
Ya, I was just curious to see what would be going bad soon and what I should keep an eye out for.
Old Oct 28, 2007 | 01:07 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Hadn't heard that one. What are the symptoms?
Old Oct 28, 2007 | 07:39 AM
Engine: 350 4BBL
The grease in the bearings dries out over the years and it will start rattling...
right before it locks up.
If it's on a serpentine setup, it then becomes "tow-truck" time ...
They're not very expensive or hard to replace.
Old Oct 28, 2007 | 10:02 AM
ljnowell's Avatar
If you are discussing the SBC in particular, yes there have been some problems with it. Core shift and lifter bores improperly bored being two that quickly spring to mind. Getting a block that cant go .030 over or eats cams sucks. The RMS has been the plauge forever. The one piece likes to leak too. But they run good enough to make you overlook all that.
9192camaro
16
Feb 3, 2019 12:21 AM
tom1985
Apr 19, 2016 07:55 AM
BHR
Sep 3, 2015 07:51 PM
mrestrictrplate
Aug 27, 2015 11:54 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
