Hydraulic Cam With rollers?
Old Oct 27, 2007 | 11:41 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
What would happen if I were to use a hyd. flat tappet cam with hyd. roller lifters? Does it make a difference? or is it just dumb and I am an idiot for asking a supid question?
Old Oct 27, 2007 | 11:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Hydraulic Cam With rollers?
Won't work. The ramp rates are wrong too fast too soon for the rollers, it'll also try to spin them in the bores. You'd need a way to keep the roller lifters from spinning (and if your block is setup for that, might as well get a roller cam as well eh?). Nah, just won't work, gotta match up the right parts.
Old Oct 28, 2007 | 12:09 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Thanks for the info my friend...Yes my engine is made for hyd. rollers...something else just popped into my head... could I run a 12.2:1 comp ration on ragular gas...well obviously nothing less than premium... what would be the rsult?
Old Oct 28, 2007 | 08:12 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
10.5 is about the max with 93 octane. You can get by with 11:1 if you use a sack-full of tricks...(cam with lots of overlap, recurved dizzy, shift points in transmission moved higher, stall converter, engine under-idle shutdown to name just a few)
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
