Valve guide question
Old Nov 9, 2007 | 10:50 AM
Doherty13's Avatar
if i break a valve guide on a cast head can i have it punched out and replaced?
Old Nov 9, 2007 | 11:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Valve guide question
How did you break a valve guide?
Old Nov 9, 2007 | 11:57 AM
Doherty13's Avatar
it was cracked when i removed the head..., when i removed the valvespring a chunk fell out
Old Nov 9, 2007 | 12:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sounds like you need a new head.
Old Nov 10, 2007 | 11:18 AM
Beast407's Avatar
A competent machine shop should be able to bore out the cast-in guide and drive in a replacement "false" guide. The valve seat will have to be reground at the same time.
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
