what to do?
Car: 92 RS
Engine: 350 Carb'd (almost TPI)
Transmission: 700R4 (soon a T-5)
Axle/Gears: 3.23's
what to do?
I have a 92 camaro with a carburated 350 in it. I'm not sure what I want to do next. So far I have done cam, headers, exhaust. This winter I am putting a shift kit, corvette servo, posi rear end with 373's. I'm going to have roughly 350$ extra to spend. I am looking for any and all suggestions.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: what to do?
oh definitely SFC's.
However, which cam and headers did you use? What 350 is it? basic '70s flat tappet block? What heads are on it?
Car: 92 RS
Axle/Gears: 3.23's
Re: what to do?
The block is a 74 350 out of a Nova with stock heads. It has hedman headers. I put a Summit cam in it with .488 exhaust lift and .465 intake lift with 292 exhaust duration and 282 intake duration. Could you tell me what SFC's are please? Thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: what to do?
Subframe connectors (which, of course, stiffen the unibody).
JamesC
JamesC
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: what to do?
if it is indeed out of a 74 nova the heads on it will be crap and that is way too much cam for them... that's a recipie for one dog on an engine..
Car: 92 RS
Axle/Gears: 3.23's
Re: what to do?
I knew that my heads were **** and one of my ideas that I had was to get them ported and polished and then to get my intake ported as well. Would that be a good idea, or should I just save a few more pennies and buy some new heads?
Car: 1982 Trans-Am
Re: what to do?
Yep, save your cash.
Don't bother porting a stock intake. Or porting an aftermarket one, you're wasting your time.
Porting the stock heads is just a waste of time, particularly those heads. I'd just save up and get some entry level aftermarket ones.
Car: 92 RS
Axle/Gears: 3.23's
Re: what to do?
Any suggestions on what brand of heads to get. Also what specs should I look for. I'm familiar with everything but still have a lot to learn so any input is appreciated.
