fuel filter help
Old Nov 19, 2007 | 12:02 PM
jpmlax's Avatar
fuel filter help
i am working on a 1988 camaro 305. when trying to replace the fuel filter, i stripped the outlet fitting. i was able to get the other side (inlet) off, but i dont know what to do about the outlet fitting. ive used pb blaster, vice grips, and the wrench i was supposed to use (5/8) which originally stripped it, but no luck. any ideas?
Old Nov 19, 2007 | 12:49 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: fuel filter help
could always use a pipe cutter, cut it off, get a new fitting, double flare the end and install the new fuel filter.
two vice grips???
Old Nov 20, 2007 | 09:35 AM
jpmlax's Avatar
any other ideas before i hack my fuel line? ive been told to cut it by others, but that is a worst case kinda thing for me.
Old Nov 20, 2007 | 09:42 AM
84redta's Avatar
yea it def a last resort but one that would work none the less. Two vice grips and another day of pb blast?? Maybe try and hack the fitting off the fuel filter before you cut the line and maybe you can pb blast the fitting from the inside? I don't know, just a couple thoughts.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
