Hard Start
Old Nov 22, 2007 | 05:08 AM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Hard Start
My Trans Am won't start right up. Why would it take about 20-30 seconds of cranking before it does?
Old Nov 22, 2007 | 07:13 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Hard Start
Check your fuel pressure and make sure you have good spark.
Old Nov 23, 2007 | 12:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Hard Start
You need to focus on your one thread in the carb board and figure out your choke settings. Chances are it's WAY off, and maybe your acc pump is leaking and/or the float bowl leaks.
A carb rebuild may be in order, then set it all up right and you should be fine.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
