explain the Heater Control Vacuum Tank and how it works
Transmission: A4
Do we really need this tank hooked up for the heat to work right? I broke mine and never reused it. I have since just rerouted all my vacuum lines and bypassed all unneed stuff.
Car: check
Engine: check
Transmission: check
Re: explain the Heater Control Vacuum Tank and how it works
If it is what I am thinking of it is straight forward: the tank holds vacuum, when the driver presses the go-pedal to the point that manifold vacuum is lowered, the tank supplies vacuum to hold the heater and/or A/C doors and coolant valve in the proper positions.
Otherwise the doors and coolant valve would change their postitions as vacuum was lost.
The check valve also plays a part in this.
On some vehicles this vacuum tank is referred to as the 'orb of power.'
RBob.
RBob.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
haha, the old orb of doom!
Like Rbob said, without a reserve of vacuume, when you mash the go pedal your heater controls will go nuts (vents will default to defrost with no vac) and can also be a major issue if you use the cruise control.
Personally i tossed mine across the yard along with many other usless cluttering things under the hood. but then again i dont have the cruise and my heater controls are mechanical so its no big deal.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
just get a 82 or 83 vacuum tank thing. they mounted up on the firewall this way you don't have to run a mess of vacuum lines and it still looks neat.
Transmission: A4
is it really noticable when the heater doors start messing up when you mash the gas?if its not then I wont bother reinstalling the part. also does anything else woprk along with this thing? I took a lot of stuff out of my car. I do recall that this part was located on the drivers side behind the fender and only accessable from under the car. There is no electronics plugged into so maybe I could just run sme new lines to it. Does anyone have a diagram of how this thing should have been hooked up vacuum wise
not a big issue for the heater doors. but the cruise will be noticable.
their should also be a vacuum line that goes to the pollution cannister.
i am re doing my engine bay in my 85 TA and i am looking for a complete diagram for the vacuum lines and tank. so if anyone knows where i could get one from please share.
i am just not sure about their point to point connections
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
The_Phoenix
Feb 4, 2016 07:10 AM
