Heater Issue
Old Dec 2, 2007 | 10:55 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Heater Issue
I have an unusually problem. On my stock 91 z28 the heater does not work when the car is parked and idleing.
The fan blow but the air is not warm. Drive the car and the air heats up. This car is seldom driven and its not a big issue. The car does have a huge aluminum radiator in it and a 160 t stat drilled, But the car has done this prior to these pieces being added. This has been going on for about 8 years. Again not a problem just a curosity of mine. Also the car has an aftermarket chip in it.
Its this some computer related vaccum valve not diverting hot water to the heater core?
Old Dec 7, 2007 | 02:16 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: Heater Issue
change your t stat to 180 or more and see what happens
Old Dec 9, 2007 | 09:08 AM
ljnowell's Avatar
Re: Heater Issue
Have you checked your coolant level. A slightly low system will do this quite frequently.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
