Tach Filter....do I need it?
Old Dec 15, 2007 | 09:39 PM
tiek101's Avatar
I have installed a 84 Z28 instrument cluster in a 80 Buick Regal (custom dash). I've managed to get everything to work with the exception of the tach. I'm going to try the resistor fix for the tach tomorrow (it is pegged) but since I do not have the camaro wire harness, I do not have a tach filter. I'm running a non CC HEI distributor. The question is, is the tach filter needed? I was running an aftermarket tach without a filter and it of course worked fine. If the resistor fix works then my question will be answered I suspose. But again, do you think I need the filter to make the tach function properly? -thanks
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
