Alternator
Car: 84 Trans Am
Engine: 350 mystery engine
Alternator
Hey, I have an 84 trans am and I just replaced the alternator but on the alternator there is a plug. There is a red and black wire in one hole and a black wire in the other. The red and black one broke and I cant find the other piece of it and was wondering where it goes and what it does because the alternator isnt charging the battery. the car will start with a jump and and the battery is less than a month old. Any Idea where the red wire went or even what the plug does. Thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Alternator
Those are the connections for the field windings and voltage regulator. The alternator won't produce a volt without them.
Car: 84 Trans Am
Re: Alternator
any idea where the red wire is? the black one is hooked up but the red one is only an inch long but plugged into the plug
Engine: 383 Carb
Transmission: 4L60
Re: Alternator
IIRC, there should be a red one from terminal A that goes to the battery stud, and a brown one on terminal B that'll disappear into the wiring harness.
Car: 84 Trans Am
Re: Alternator
Since I cant find the red wire, can I just crimp a wire from the terminal to the post?
Engine: 383 Carb
Transmission: 4L60
Re: Alternator
Yes, you might have the entire wire right there, just missing the connector on the end of it. Crimp a ring on it and attach it to the battery stud if it reaches.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Alternator
on my car one wire went into the harness and the other attached to the positive stud on the starter
Car: 84 Trans Am
Re: Alternator
Would it hurt anything if I just ran a cable from the battery instead of the starter?
Engine: 383 Carb
Transmission: 4L60
Re: Alternator
No, but it's easier to just connect to the battery stud on the alternator.
Car: 84 Trans Am
Re: Alternator
Is the plug responsible for charging the battery, because the car will start with a jump but the voltage will steadly decrease from 13 to 11 and then die.
Car: 84 Trans Am
Re: Alternator
Hey whenever I put the wire to either the stud on the alternator or the battery post itself the car will not even crank. with the wire off the car will crank but the battery wont charge, any ideas?
raymondandretti
Sep 27, 2015 06:43 PM
