Pistons: Forged vs. Hyper? Are forged hard to live with?
Getting ready to redo a bottom end. Might see some boost down the road. Looking at forged pistons and wondering if they are difficult to live with.
From what I gather, forged are loose in the bores when cold and expand to fit properly after they've warmed up. Apparently they rattle and you get piston slap when cold.
With forged pistons, do you need to let the engine warm up before you pop it in Drive? How long?
Do the loose pistons at cold startup wear out the bores faster? Is this significant? Are there other longevity issues with forged vs. hyper?
Can you still run a .040 quench or do you need to open this up due to piston rock at cold startup?
What has been your experience with forged pistons?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Pistons: Forged vs. Hyper? Are forged hard to live with?
I have never had any of those problems that you described with forged pistons. Never. Not once...
I ran the piston to bore clearance that TRW and Speed Pro told me to. I don't remember back then if that was different than stock specs or not. I just did what they said, and it was fine.
I have had a grenade failure with the hyperutectic pistons. Apparently they don't like to run lean. My partner was in the burnout box and then -BAM- one more 355 on the scrap heap. I'll never run those again, the forged don't cost that much more.
If it's a money issue and you just need a little more for forged, take a pizza job for a month and then buy the forged. Otherwise, new cast flat tops are good.
If you are going to run any boost at all, You should use forged. I always use forged, and I have not worn out a bore from it. You make your engine sound like a piece of glass. It is not. A good engine builder will have your engine fine with the piston clearance. If you are running fuel injection, Start it up and drive it off, just like you would any other engine.
- The engine is a mild 383 (6.27 liter)
- (5.7 liter-350 cu in block, with 4.030 bore and 3.750 in stroke)
- Using a new stand alone TPI harness, without the EGR, or VATS.
- It uses VSS, and 3 wire O2 sensors.
- The Engine has 10-1 compression
- MAHLE forged pistons flat tops SBC-425030F05.
- Eagle 5.7 H-Beam Connecting Rods
- Forged Summit One Piece Rear 383 Crank
- AFR 195 Eliminator cylinder heads part #1038
- 1 5/8 in headers.
- Comp Cams 08-467-8 cam, 280XFI HR13
- Intake Duration 280,
- Exhaust Duration 288
- Intake @ .050 230
- Exhaust @ .050 236
- Valve lift intake .576
- Valve lift exhaust .570
- Lobe Angle 113°
- Hydraulic Roller Lifters
- The intake is a Modified LT1, Front matched to the Twin 58mm for increased flow, and Entrance and Runners Polished.
- Fuel is delivered through 36# Holley injectors
- The throttle body is a BBK twin 58mm
KrisW: Which forged pistons were you using?
Here's why I ask:
Talking to a local engine builder about the SRP 5.7 rod 31cc inverted domes for a Vortec 383 which would put me at 8.5 to 1. He said that even though they have high silicon content and are more dimensionally stable than most forged pieces, you won't be doing any ambulance runs with these. You need to let the engine warm up.
Talking to a tech person at JE about their 6 inch rod 28cc forged inverted domes (8.8 to 1), he says with the SRP or the JE, they are going to make noise when cold.
How big of a problem is this?
Here's why I ask:
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I've got SRP forged. I do feel it is always good to let your engine get to operating temp before going WOT buuuut I have never had an issue with noise. You'll be fine. Go forged.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
im in the same boat as far as going forged or not. i think forged is a better choice but i also heard that hyp pistons are better for a daily driver.... once u throw boost at it you change that... go forged as i will be doing the same for my 383 that i might boost later in life.
hey psy4s!
wat are u getting with your combo... mine and yours are very close, and im in the process of putting mine together. i have all the parts except the rotating assembly.
im goin wit 383 1piece seal roller block
HSR... ported and portmatched to felpro1206
patriot 195cc heads, ported, port matched to felpro1206, roller cam dual spring upgrade good for .671 lift, polished stainless valves, vitton seals, 5 angle valve job, partly CNC bowl blend.
XFI280 cam
1.6 extruded full roller aluminum rockers
58mm TB
30#SVO ford injectors
grannelli MAF
new true roller timing Cloyes chain, new hydraulic lifters, comp cams extreme energy .100 longer pushrods
Kirbane billet adjustable fuel regulator, walbro255 high pressure pump.
im looking for 480hp mabye 500 if i do alil more to the heads or something. what you pushing out or running in the 1/4???
hey psy4s!
XFI280 cam
58mm TB
grannelli MAF
Car: '82 Z28
I've been running forged pistons from Wiseco for 4 years, 2 of those years the car was my daily driver. Never had an issue of jumping in the car and driving down the road. I don't ever recall hearing piston slap when cold. When I had the heads off the engine last year to bump the compression up, the cylinder walls looked great.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My engine has forged pistons but isn't driven on the street. I don't notice any piston slap when I fire it up. During a race day, I fire it up in the morning to build heat in the engine then shut it off and let the heat soak through the entire engine. I don't have the benefit of running the engine for long periods to build a lot of heat.
JE and SRP are both good forged pistons. I use JE because they're lighter than SRP. More for a race application than street use.
Engine: 2.8/TBI/TPI
Here's why I ask:
Here's why I ask:
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
i used to get piston slap when it was real cold out with my speed pro forged pistons but since i went from cast heads to aluminum heads i no longer have the noise
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've HEARD that forged will wear the bores out faster. Heard. Hasn't happened to me yet. I've also actually heard piston slap with forged slugs in my buddies 79 Ford somethingorother. I haven't heard any slap in mine though. But it's kinda hard to hear much of anything over my exhaust.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Forged might be heavier, depends on the piston, but something to look at.
Typically the downside is the price. If you don't need 'em, don't waste the cash on them. I dare say 80% of the people who buy forged pistons don't really need them. I'm talking about the guys with a 350-400HP SBC NA, running forged pistons because a buddy told them to. Cast would be fine there, or hyper.
To me, forged is only needed for LARGE amounts of nitrous, and/or a big blower or maybe a high revving turbo motor.
TRW/Speedpro ones are cheap enough that if you're confident you'll have boost in the (near?) future, give'r.
This should be exactly what you are building. It even has the heads you are using. I am sending you this because it is what I used as the pattern for mine. Mine should flow a little better since I am using AFR heads, but I do not know that for sure. To pick my cam, I actually called Comp Cams and gave them all the information for my car. The cam I am using, and injectop size was per their instructions. I wont have access to a Dyno or the race track till spring. Then I will post my actual numbers.
Use the link at the bottom, It will take you to the web site. It is a pretty good site.
http://www.golenengineservice.com/html/fi_facts.html
Peak Horsepower: 500 bhp @ 6400 rpm
Peak Torque: 475lb/ft @ 4000 rpm
Operating Range: 2500 - 6400 rpm
Compression Ratio: 10:5:1
Required Fuel: 91+ Octane Pump Gasoline
Base Price: $12,499.00
Chevy 383ci / 500hp TPI Mini Ram Turn-Key
The 383/500hp TPI Mini Ram is a great performance fuel injection package for vehicles originally equipped with TPI engines. A good idle, smooth power delivery, and excellent performance are just some of the high points of this package. If you are looking to convert your old carbureted hot rod to fuel injection, you simply need to add a wiring harness and computer. Please call our sales line for assistance with fuel injection conversion packages
Car: 87 TA clone
thanks psy4s, i guess i should be expecting around that except my comp ratio will be lower so i'll prob loose alil hp. but i should make more tq bc of the HSR over the miniram and LT1.
thats exeactly what i heard about forged pistons and why they are not better than hyper bc they where the bores out faster and seem to heat and cool (expand and shrink) slower than hypers. which is not a good thing for daily drivers. still since many havent had problems i guess they would be ok. if u set them correctly with the rings etc.
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
HI, I have a set of forged wisco pistions in my snowmobile and I burned the top right off in to the exhaust manifold b/c it was running lean... SO I baught a set of good HYper ones for my 350 I figure I saved around $300 witch is a bit of money but will find out if I should of went better when I start running it hard.
Breazlan
Sep 25, 2015 11:20 AM
