boggin problems
Old Jan 22, 2008 | 09:30 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
boggin problems
please help me.my car is bogging ever since i broke my hose that runs from one side of the engine to the other (on the top).it connects to the driver side exhasue pipe and connects to the somg pump connector(air pump pieces) ever since then my car bogs wen i punch it out n then kicks in.i dont peel out no more. do i need to remove all my smog pump shi* casue its gettin to much air o somthin
Old Jan 22, 2008 | 09:35 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: boggin problems
was it a rubber hose? if so why not just replace the hose. without that hose on the top of the exhaust manifold to the air pump, its the same as having an exhaust leak if im not mistaken.
Old Jan 22, 2008 | 09:36 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: boggin problems
try replacing the hose because all that smog pump does is pump air down into your cat and it helps the fumes combust better by helping it as a catalyst too much air to the cat wont affect your performance to my knowledge and if you remove it and you try to go through emissions you'll be screwed if they do an underhood check, they wont even test it if you delete it.
Old Jan 23, 2008 | 09:14 AM
Car: 86' Z28 Camaro
Re: boggin problems
but my frineds all have the same 305 n they took theres all off n theres is fine.i dont get it.
Old Jan 23, 2008 | 12:52 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
Re: boggin problems
Do they have aftermarket headers? Headers might not have provisions for smog, so no holes, therefore no leak.
Old Jan 23, 2008 | 02:35 PM
Car: 86' Z28 Camaro
Re: boggin problems
nope
Old Jan 23, 2008 | 11:26 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: boggin problems
you need to look deeper into then
Old Jan 24, 2008 | 10:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably not related to the A.I.R. hose.
That's a classic quadrajet symptom when the secondary AV opens too quickly. The two controls on that are the choke pull-off diaphragm (called "vacuum break" by GM) and the AV tension spring. See the sticky in the top section of the Carburetor forum about the E4ME. Both are shown and discussed.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
