how collacky is your 350?
Old Jan 23, 2008 | 11:18 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
mine has got to be one of the worst. if i dont start it for two or three days, it doesnt want to start the first few times. if it is under 70*F or over 80% humidity it doesnt want to start. i have a carb rebuild kit on the way, have replaced fuel filter, plugs, cleaned up distributer, it has good everything else, it just doesnt want to start. i give it plenty of gas. any recommendations? is anybody else's like this?
Old Jan 23, 2008 | 12:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: how collacky is your 350?
What carb?
Sounds like the fuel is evaporating from the carb, or leaking out the bottom.
Mine does that, so I JB welded the well plugs on my Q-jet. I forget if it kept doing it. I just made sure to start it up more often.
The humidity and temperature thing is another matter. The choke probably isn't working right. What type of choke is that carb outfitted with?
Old Jan 23, 2008 | 07:36 PM
impaled's Avatar
yea, im sure it will get better after i rebuild the carb, but thanks for some ideas. im sure the carb is leaking or something because it had about 13 psi of fuel pressure running through it for who knows how long. more ideas are welcome.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
