what distributor to buy?
ok here's the deal. i have an 86 LG4 camaro, computer controlled quadrajet set up of course. i am going to ditch it because my quadrajunk is all screwed up. i have a non-computer edelbrock carb and intake to throw on, but i do not know what distributor my situation requires.
what dizzy should i buy?
vaccum advance?
hei?
mechanical advance?
what the hell is the difference?
will it work with my stock ignition set up?
vaccum advance?
hei?
mechanical advance?
Re: what distributor to buy?
vaccum advance?
hei?
mechanical advance?
vaccum advance?
hei?
mechanical advance?
Car: 88 Camaro
Engine: L98 350
If I remember right the 86 is still a flat tappet cam? If so a standard HEI with vacuum advance is fine. Just tap into the power wire to the old coil and run to the batt terminal of the new dizzy.
i mentioned in the original post that i am not doing this swap for hp. my quadrajet set up sucks. it is shooting gas into my air cleaner at high rpm, rather than into my intake, causing sputtering. also runs rich at times. i have removed my smog. i figure why not go the whole way and just junk that stock crap and go completely mechanical. i will also be putting my headers on, so i expect a good hp increase.
BumpaD82
Feb 26, 2016 02:57 PM
