what heads do i have?
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
ok i was wondering if anyone could tell me what heads(cc,valve sizes,etc) came on the factory 305 in the 82 Z28,i kept the motor n tranny and was wantin to use the heads on my 350 that has sum crappy truck heads since the 350 came out of a truck,im goin to check tomorow on the heads to get the casting numbers but any help will be appreciated
Re: what heads do i have?
truck or car has nothing to do with it
most of the time the same heads were used regardless if car or truck
what casting number do you have
need that info to know anything at all about what you have
the most common 80-up 305 heads were the 4416 ones
58cc
1.84 valves
58cc
1.84 valves
ok this may sound stupid but where all should i look for the numbers
ok the numbers i got is this
14014416
GM3
21
l18-1
theses were all on top of the heads,on the bottom side i found 2 sets of numbers
looks to be 524 and c45 or maybe G45 or 045 i couldnt tell so that may not be right
and they have this on the side of them
14014416
GM3
21
l18-1
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
416 is all that matters. You have the same heads as everyone else on here with an '82-'88ish 305.
Specs are what Randy mentioned.
so are they worth it to get new valves and have them cleaned up and use on my 350 or should i junk them
Car: 1982 Trans-Am
Yes, port and polish and upgrade the valves. See sig.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
