2 Loose spark plugs???
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I looked at my car today and I see that oen of my plugs looked loose. I had a problem with my new doug headers. The #7 spark plug is impossible to be touched with a socket. So i used pliers to tighten it. I used a good set of rubber to keep the plug in tact. Anyways i loked today and the plug was actually semi loose. It freaked me out. I also found out that oene other one was loose but. It is all good now I hope.
Anyways weird question. My plugs go in the ytighten up then the yloosen again and then they are tightened finally. Is this proper or are my plugs wrong for my car????
Re: 2 Loose spark plugs???
It's not impossible that you have the wrong plugs; but more likely, you're just not getting them tight enough.
Let your "will" power overpower your "can't" power.
"Can't" is no way to go through life. Thread Starter
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
lol well the only possible way is pliers. I have had 2 mechanics, myself and my dad try. We had crows feet bent wrenches, you name it we did it. I did get it to go thogh.
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
what do you mean you "did get it to go" i hope that you threaded it in with your fingers first or bye bye threads hello loose spark plug
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
no i did. I mean it finally tightened up the way i wanted it to. It was in such a hard spot it wasnt tightened as much as i wanted.
