Trick Flow Spark Plugs
Old Feb 24, 2008 | 11:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Thought I would post this info I found out. Turns out that the spark plugs that Trick Flow reccomends for their heads are the exact same spark plugs Dodge recomends for their 94-99 Neon SOHC 4 cyl cars. Even the heat range is right. So when you need to get new spark plugs and you forgot which ones all fit you can go to any autoparts store and tell them you need 8 spark plugs or the prementioned 4 cyl engine (they'll look at you wierd, they always do).
Old Feb 24, 2008 | 11:12 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: Trick Flow Spark Plugs
Tibo,
I did not know that. Are they the full length plugs or shorty header plugs? What brand is it or is it any brand that covers that type of car?? I run the fr3ls plug acdelco number.
Rabi C.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
