Getting desired compression ratio?
Old Feb 29, 2008 | 03:01 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
ok im going to build my own engine and i want it to have 10.5:1 compression. it will be a 350 bored .030" over and have dart 220 heads. the piston style and rod length determine CR right? does anyone have advice or pointers? it will be naturally aspirated with ram air. anything else needed, let me know. thanks!
Old Feb 29, 2008 | 03:34 PM
ljnowell's Avatar
Re: Getting desired compression ratio?
The first thing I would do is get rid of those heads. They are one of the worst possible fits for your project. You would have to be spinning this engine to nearly 8k to use those heads, not to mention the horrible loss of bottom end. Get some better heads. Sell those to someone building a big cubic inch smallblock, or a circle track car.
Then start over. Pick a head, then decide on piston. If possible a slightly dished piston would be best, with the block decked to suit. This is honestly the best way to go about it for quench purposes. iron heads, dont try to go higher than that 10.5:1 mark. Use good gas, and make sure you know how to set it up. thats pushing it.
Old Feb 29, 2008 | 03:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Displacement and combustion space volume determine CR. Rod length has nothing to do with it.
Old Feb 29, 2008 | 03:58 PM
Engine: 5.7 LSX
ok cool thanks for the advice. so can u recommend better heads? its gunna be a daily driver but i dont drive far (small town) and i treat every light like a drag strip kinda. i wanna be able to toast anyone else who pulls up to me in their modded daily driver. especially all the *****s around here who think their car can do mach 5! all noise and no guts to back em up! anyways... so?
ok, ok... imports. sorry.
Last edited by 85projectZ28; Jan 27, 2010 at 05:10 PM. Reason: Automerged Doublepost
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Royal_Z
Sep 30, 2015 08:45 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
