compression questions
Old Mar 5, 2008 | 12:28 AM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
ok my car had 9-1 compression when i had it rebuilt and now i put 64 cc heads on...will it make my compression go up? if so do you guys have any idea how much?
Old Mar 5, 2008 | 12:37 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: compression questions
what cc heads were on it?
Old Mar 5, 2008 | 12:38 AM
mbolte's Avatar
Car: 1987 Camaro
umm the heads were stock i dont know what that would be for cc
Old Mar 5, 2008 | 12:44 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
kinda hard to say.......but unless you had 305 heads on it the comp will probably go up or stay the same.........compression ratios are hard to give a round about when you dont know what you have.......flat top pistons? domes? dished? if you have flat tops with a 64cc head you will be close to 10.5
Old Mar 5, 2008 | 12:48 AM
mbolte's Avatar
Car: 1987 Camaro
the heads are stock 350 heads that were on the car...the shop that built it just said that the pistons would give about 9 to 1 compression?
Old Mar 5, 2008 | 12:54 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
chevy made 3 differnt stock heads with differnt comp ratios.......corvette heads were 58cc.........double humps were 64cc.........882 were 76cc........................if you were running 882 and had 9-1 ratio......with 64 cc heads you maybe around 11-1..........im almost 100% sure you have flat tops though, and you should be around 10-1
Old Mar 5, 2008 | 01:43 AM
mbolte's Avatar
Car: 1987 Camaro
ok cool...for 10-1 would it be necessary/better to run higher octane then 87?
Old Mar 5, 2008 | 02:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get the casting #'s off of the heads that were on the engine. Located under the valve cover, between a couple of valves.
Until it's known what heads you had, speculating about what change there was with 64cc heads is moot. You may have made things better, you may made things worse.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
