car wont start...oops
Old Mar 12, 2008 | 07:49 PM
Booda_33's Avatar
Car: 1982 Trans Am
Engine: Junk 305
so i got a new battery for my 82 trans am. while the alcohol was flowing i maybe put the battery in backwards. only cranked it a couple of times bafore it clicked what i had done. Now she wont start. cranks fine...I've got fuel...what would be a good place to start looking to fix this problem. the gauges work fine and the lights all come on. its a 30 over 305 carbeurated.
Please help
Old Mar 13, 2008 | 10:05 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Re: car wont start...oops
Maybe the control module got cooked? or the pickup coil?
Old Mar 13, 2008 | 10:42 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
LOL, WOW the alcohol must have really been flowing. The amount of sparks flying from the battery when you were trying to hook it up backwards did'nt clue you in?
Old Mar 13, 2008 | 11:11 PM
Booda_33's Avatar
Car: 1982 Trans Am
Engine: Junk 305
not a single spark...and everything else controlled by the ECM works fine...just got no power to the ignition coil...is there a fuseable link or an inline fuse anywhere between the ignition switch and the coil. There is one connector "C100"...and a splice "S201". but the wiring diagram doesnt say anything about a fuse anywhere...should i run a hard wire from the battery to the coil to see if it will crank or could i do more damage that way?
Old Mar 13, 2008 | 11:38 PM
You are sure theres no power to the coil? Have you done the ol' pull the coil wire off(the one that's like a plug wire) and put a screwdriver up to it and see if you get spark from it trick?
Old Mar 16, 2008 | 08:26 PM
Booda_33's Avatar
Car: 1982 Trans Am
Engine: Junk 305
got it figured out...the ignition control module basically liquified on the inside. a 25 dollar part and shes purrin like a kitten. thanks for the help tho guys.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
